Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Simulate/Manage 2013 - does it crash when you use the Selection Tree?
2 REPLIES 2
dgorsman
342 Views, 2 Replies
We haven't upgraded our licenses yet but I am testing Freedom 2013.  Whenever I click on an item in the Selection Tree under the Properties tab, Freedom crashes immediately.  This doesn't happen in the the other two tabs (Standard, Compact).
Would somebody please check to see if this also happens in Simulate and/or Manage 2013?
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
2 REPLIES 2
JeffH_ADSK
in reply to: dgorsman
Hi there,
This is something we are aware of. There is also another thread covering this here. The issue is unique to Freedom; Manage & Simulate are unaffected. It is being looked into.
Hope that helps,
Jeff
Senior Software Engineer
Navisworks
Autodesk Ltd.
dgorsman
in reply to: JeffH_ADSK
Thanks, that does help.  The Freedom users here don't use the Properties tab very often, so the only concern was if it was across the higher-level versions.
Rail Community
