Navisworks General
New Member
Message 1 of 3 (1,600 Views)
Silent install for Navisworks Freedom 2010
1600 Views, 2 Replies
02-16-2010 05:40 PM
Hi ,
How can i make a silent install package for navisworks freedom 2010?
is there any documentation for creating a redistributable install.?
The PC's i will be distributing the program to already have msxml and MS C+++ 2005 and 2008.
all i need to install is the nlsdl and the program itself
the command line i have used that worked with freedom 2009 is
msiexec /qn /i "\\%z_drive_server%\%z_drive_path%\app\Autodesk NavisWorks Freedom 2010\x86\NAVFREE\freedom.msi" TRANSFORMS="\\%z_drive_server%\%z_drive_path%\app\Autodesk NavisWorks Freedom 2010\x86\NAVFREE\freedom.mst" ALLUSERS="2" /m MSIVOUIE
however after the program is installed and launches it crashes with some C++ errors
can anyone assist
thanks
Vondutch
New Member
Message 2 of 3 (1,594 Views)
Re: Silent install for Navisworks Freedom 2010
02-16-2010 07:06 PM in reply to: vondutch1
Worked it out ...
it needed the language pack before it would work
msiexec /qn /i "\\%z_drive_server%\%z_drive_path%\app\Autodesk NavisWorks Freedom 2010\x86\NAVFREE\en-US\NAVFree_LP.msi"
Message 3 of 3 (1,594 Views)
02-17-2010 01:01 AM in reply to: vondutch1
Vondutch,
It's easiest to do this if you have the Freedom installer rather than Manage/Simulate/Review -- if you do not, you can download Freedom easily enough from the Autodesk site. The official way to do it is run setup.exe like this:
setup.exe /w /t /qb setup.ini /language en-US
That takes care of all the pre-requisites and puts the language pack on too.
Your procedure looks broadly OK to me, however, we do not test or support per-user installs which potentially could occur as you are specifying ALLUSERS="2".
Andy
You are not logged in.
Have API Questions?
New Dedicated Forum for Navisworks API
Need installation help?
Ask the Community
