Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Selection Tree dissappeared - Help!
8 REPLIES 8
Message 1 of 9
mradamdavis
4154 Views, 8 Replies
I have mistakenly floated my "selection Tree" pane off of the viewable area in Navismanage 2013.   I have run a repair, and I have re-installed Navis, however, I cannot find my Selection Tree Pane.   I have been able to use the "Find" pane to access the tree, but I would like it back.   Any ideas on how to get it docked back in?
Adam
8 REPLIES 8
Message 2 of 9
dennis
in reply to: mradamdavis
Is your Selection Tree actually on?  Goto View/User Interface and check.  If it is on, but "off screen somewhere", try changing you screen resolution.
Message 3 of 9
mradamdavis
in reply to: dennis
Dennis,
Thanks for the input, I do indeed have it "on" and I have changed all available resolution levels with no luck.   Just got a response from Autodesk today, it requires a "regedit" to fix.   They have no other way to "fix" this when it happens.
Adam
Message 4 of 9
dennis
Ouch, RegEdit....that is ugly.  What were you told to do?  For future reference should it happen to others...
Message 5 of 9
mradamdavis
in reply to: dennis
Dennis,
They gave me a "regedit" link for Map3D that does the same thing, however, the instructions do not correlate to Navis.  I have re-submitted the tech request.....  I will post fix after it is done.
Message 6 of 9
JeffH_ADSK
One thing to try would be resetting your Workspace. This restores all panes within Navisworks to a default layout.
To do this, go to the View section of the Ribbon, select Load Workspace and select one of the standard ones e.g. Navisworks Standard. This will reset all your UI layout, but you should find the Selection Tree is back & docked hidden on the left when activated.
Hope that helps,
Jeff
Senior Software Engineer
Navisworks
Autodesk Ltd.
Message 7 of 9
vmurugandev
press ctrl+F12 to enable hide or show the selection tree
Message 8 of 9
vmurugandev
press ctrl+F12
Message 9 of 9
Paul.Locher.SG
in reply to: JeffH_ADSK
I had a similar issue and message #6 fixed it for me.  Thanks a bunch!
Rail Community
