Before when I want to select just one wall, or one door, and hide it - I could just click on the door and click hide...
For some reason now, When I click on that same door, it highlights the ENTIRE model that the door is in, and not JUST the door.
What do I need to do differently? The files are .NWC and were made from Revit.
I swear I have alawys done the same things and never ran into this problem before? Is it as easy and chance a setting in the global options?
HELP!
Thanks.
Solved by dgorsman. Go to Solution.
Check the Selection Resolution setting. Its probably set to pick something very high up the selection tree.
