Navisworks General
Wouiss
Message 1 of 3 (233 Views)
Select same properties
233 Views, 2 Replies
10-03-2011 12:28 PM
Hi!
In the Select and Search panel, you have the option to select the object with the same <property>. Inside my model, there is like 20 properties for example: equip #, iso #, line # etc.
Can I select which property I want the model to look at when I click on Select same -> properties
When I select a pipe for example, I would like to select all the pipe that as the same line #. When I click on select same - properties, nothing happend. Why? Is it because all the properties need to be the same to be selected?
I know I can get all pipes with same line # if I select that line # inside the selection tree-->properties tab--> line # but I need something quicker than that.
I tried to changed the selection resolution but no one is made for my need. In a perfect world, I would like to add another tab to the selection resolution for line #!
Does anyone have a solution?
Product Support
lee.mullin
Message 2 of 3 (190 Views)
Re: Select same properties
10-11-2011 09:15 AM in reply to: Wouiss
Sorry about the delay on this. It's a current limitation but I have added an enhancement request about this.
As you state the current workaround at the moment is to go through Properties in the Selection Tree.
You may be able to do this through the API, I'd suggest asking a question there
Lee Mullin
Product Support Specialist
Global Services
Autodesk Ltd.
Member
venom_projects
Message 3 of 3 (83 Views)
01-25-2013 10:19 AM in reply to: lee.mullin
I'm wondering about the exact same thing, being this is an older post was there ever a solution for this?
Doug
You are not logged in.
Have API Questions?
New Dedicated Forum for Navisworks API
Ask the Community
