Thsi is for Navisworks 2013 Manage.
I just happened to have this sort of sectioning effect while I navigate the model (walk tool)
I was reading some of the older posts suggesting to change the setting of "culling" and the clipping plane?
I tweaked little bit and didn't seem to change anything.
Can anybody give me a feedback what's the right setting for the culling and clipping plane, please?
Thanks in advance.
Solved by steveperkio. Go to Solution.
Thank you for your post and also thank you Patrick for your suggestion. In the product there are a number of settings and depending on the values themselves, the resultants can be very different. How did the suggestion above work out? For reference I have included a helpful link below on this feature. Please keep us posted in the community and let us know if this helped. Thank you.
Overview of Viewpoints: http://docs.autodesk.com/NAVMAN/10.0/ENU/Autodesk%20Navisworks%20Manage%202013%20Online%20Help/index...
Overview of Sectioning: http://docs.autodesk.com/NAVMAN/10.0/ENU/Autodesk%20Navisworks%20Manage%202013%20Online%20Help/index...
The problem is like I don't want the sectioning effect but it still gives me the sectioning effect even with the sectioning dsabled.
Can I email you the NWD file for you to look at? It's about 5MB.
David
You can upload to your post and I can then review if you would like.
