Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Seam lines display in Naviswork
6 REPLIES 6
s.gholap
1187 Views, 6 Replies
Dear Autodesk Team,
We are getting problem in Naviswork display.
When we preview the drawing in Naviswork, we display lines shown in attached screenshot by arrow marked.
The left-side screenshot is of Autoplant Drawing and right-side screenshot is of Naviswork Display.
Please let me know any option setting to be done in Naviswork or in Autocad, so that these lines will not display in Naviswork.
FYI:
We are using
Software : Autocad 2012-64Bit , Naviswork 2013 , Autoplant V8i - SS4 version : 8.11.9.140 ,  MS-Office 2010 64 Bit.
Hardware : Workstation Dell Precision T3600
Please let me know any solution for above.
Waiting for your earliest reply.
Thanks and Regards ,
Swapnil M. Gholap
Application Engineer
s.gholap@frames-group.com
Frames Process & Energy Systems India Pvt.Ltd.
www.frames-group.com
6 REPLIES 6
Lance.Coffey
in reply to: s.gholap
If you switch to a shaded view within AutoCAD, are you seeing the same lines?
Also, if you can select these lines within Navisworks (to get info to search on), you should be able to setup a Search Set to fairly quickly select all of them and then hide them.
Lance Coffey
Technical Support Specialist
s.gholap
in reply to: Lance.Coffey
Dear Autodesk Team,
After switching to shaded view,then also we are getting this seam lines in naviswork.
Please let me know any solutions.
Waiting for urgent solutions.
Swapnil M. Gholap
Patrick_Aps_9121
Options -> File Readers -> DWG/DWF
Try to swicth "Convert Lines" OFF
s.gholap
in reply to: Patrick_Aps_9121
Dear Autodesk Family,
Its already 'Off' only.
I attached our naviswork setting export file here.
Please have a look on it,which setting to be needed to remove seam lines in our naviswork.
Waiting for reply.
Swapnil M. Gholap
dgorsman
Those may be inherent to AutoPLANT components.  You may also need to check DWG version, Navisworks DWG Reader version, and object enabler version.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Lance.Coffey
My thought, as dgorsman indicated, is that these lines may be setup within the DWG file, but are not visible because of the view representation you are using in AutoCAD.
You indicated that you switched to a shaded view in Navisworks and you are continuing to see these lines. Do you see these lines in AutoCAD if you switch to a shaded view within AutoCAD?
dgorsmanDavid Gorsuch (dgorsman) *Expert Elite* 391 Kudos received 4967 Messages Posted Latest Posts
Lance Coffey
Rail Community
