Using Navisworks Simulate. I open Navisworks and the screen is black how can I change the screen to white?
Solved by dembkod. Go to Solution.
In 2011, go to the view bar, and choose background in the scene view portion of the ribbon.
The background & the stereo enable on the View tab are grayed out so I cannot click on them.
Hello LutherKinman7760 ,
You will need to have a file loaded to use the “Background” option on the ribbon. As soon as you load a file, you should see the option become available. Click the Background option and the Background Settings window will display. You can change both the sky and ground color.
Thank you for participating in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
is there a setting in the option to define a default background. it would save repetative effort and time to be able to set the horizon with a muted sky and ground default as the background.
Thanks. I figured those would be the options. I will put in the request for template files with AutoDesk. I think they would serve a variety of purposes just as DWT's and seed RVT's server their other products.
