I am using revit for modelling & navisworks for 4D. I cannot find a method to create 4D with brick wall, plastering and painting in proper sequence. Any method to break the wall into these three components to use in navisworks?
Solved by lee.mullin. Go to Solution.
At the moment you would need to create all these parts of the wall seperately in Revit. It's not an ideal solution.
We are aware of this as we know this will be useful for construction sequencing. We hope to include this in a future release.
Hi, I am facing the same problem and are there any updates regarding to this issue?
Thanks and Regards,
Rakesh R
I'm currently using NW Manage 2019 and seems like you still need to create parts in Revit prior to importing it in NW. I'm hoping they'll add this feature as it will be very helpful in creating Timeliner simulations. I'm still learning NW so I might be wrong.
