Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Revit Add-ins External Tools button is greyed-out
1 REPLY 1
tcorey
3028 Views, 1 Reply
I have installed Revit Archtecture 2012 and Navisworks Manage 2012. Revit 2012 64-bit exporter was selected during install and appears in Control Panel Programs and Features.
Inside Revit Arch 2012, I have an Add-ins ribbon tab, but the External Tools button is Greyed-out.
I have uninstalled and re-installed just the exporters, and then uninstalled and reinstalled the full Navisworks Manage application.
Using AutoCAD, I know how to manually load the plug-in, but I don't know how to do it in Revit. Can anyone point me in the right direction?
Thanks in advance,
Tim Corey
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
1 REPLY 1
dembkod
in reply to: tcorey
tcorey,
Hello. Are you in a 3d view? If the item appears but is grayed out, it is installed on your system - it is just that you are not in a place in Revit where the exporter is an active tool for your model.
Can you click the 3d view button in Revit to view your model as a 3d  solid and check to see if the tool is active?
Thank you for participating in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
Rail Community
