I have installed Revit Archtecture 2012 and Navisworks Manage 2012. Revit 2012 64-bit exporter was selected during install and appears in Control Panel Programs and Features.
Inside Revit Arch 2012, I have an Add-ins ribbon tab, but the External Tools button is Greyed-out.
I have uninstalled and re-installed just the exporters, and then uninstalled and reinstalled the full Navisworks Manage application.
Using AutoCAD, I know how to manually load the plug-in, but I don't know how to do it in Revit. Can anyone point me in the right direction?
Thanks in advance,
Tim Corey
Hello. Are you in a 3d view? If the item appears but is grayed out, it is installed on your system - it is just that you are not in a place in Revit where the exporter is an active tool for your model.
Can you click the 3d view button in Revit to view your model as a 3d solid and check to see if the tool is active?
Thank you for participating in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
