Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
: Review PDMS Model in Navisworks
1 REPLY 1
cristian.leon.gonzalez
2661 Views, 1 Reply
Hello Everyone
I'm trying to do something about it... i export a RVM file with rules like this:
\all with PURP EQ 'GRAT'\21
\all with PURP EQ 'STRU'\20
then i opened the "colors.txt" file and saved to:
C:\Documents and Settings\Christiansen\Datos de programa\Autodesk Navisworks Simulate 2010\rvm
then i change the colors as follow:
where says: "Color Assignments: " i go to the color marked as 21
21   =   LightGold
then, i search Lightgold in the lower part of the file, where says "Color Definitions:" and change the RGB color as Follow:
LightGold      =  176   238   0
I save the file, reinit the Naviswork Simulate 2010 and open the file project.rvm but the result is this:
RVM Result
where the blue color should look more bright, the plum color more grey (as concrete) the handrails, the grating, etc...
even i change the plum as red (255   9     9) and still look like the image above...
as no change are showed, i replace (making a backup, of course) the original colors.txt file in it's original location, but nothing seems to work.
i don't know if i'm doing something wrong or the file colors.txt does do nothing...
thanks in advance
Edited by
Discussion_Admin
1 REPLY 1
Can you try this with the latest release?
You can get a 30 day trial from http://autodesk.com/navisworks
If this doesn't work then you can also use the Appearance Profiler in 2012 which allows you to map colors to properties using Search Sets.
Lee Mullin
Construction Technical Specialist
Autodesk Ltd.
Rail Community
