Hi all,
I've attemtped to render a few frames of a current project with navisworks but the rendering looks very distorted and shoddy. (See attached before and after pictures)
The project was made entirely in Civil 3D and appended into my navisworks file. I'm cleared the materials pallete before applying the navisworks materials. I've double checked for a "Bylayer" material and deleted it when found, but still get the same results.
Any help would be very much obliged!
Open up the "Presenter" dialog box and delete "ByLayer" from your materials. You may have to do this every time you refresh your model in order to render properly. Hope this helps.
Have you checked Can you check the "Viewpoint > Camera > F.O.V". of your view? Reducing the value solved the problem for me.
