I'm trying to use the aformentioned file for generating a fairly large quantification catalouge.
it seems that once my catalouge exceeds approx 16,000 lines it just won't export, showing the errorbox "Overflow" (see printscreen).
any solution for this one?
Solved by thomas.schwaiger. Go to Solution.
the creation template is an excel based file. (does not run on navisworks but produces an xml to be imported by navisworks)
anyway- the machine (and office version) is 64 bit.
couldnt figure out a solution for this one, so what i've eventually done was figure out navisworks xml schema for quantification's catalog and write a macro of my own to generate a xml that will suit my company.
Thanks for reporting this issue. Our development team has resolved this with an updated versioin of the catalog creation template. We'll be publishing the updated template on http://knowledge.autodesk.com/support/navisworks-products/downloads/caas/downloads/content/autodesk-... in due course.
In the meantime I've also attached it to this thread.
Hy everyone
I am finding some trouble using the spreadsheet.
Does anyone have any instructions for using it.
I mean, the procedure to generating a valid xml file of the catalog created.
I want to use it to generate a masterformat catalog to put into navisworks quantification.
Borja
