Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
QTO - Reimporting Catalog
6 REPLIES 6
rgilbim
1045 Views, 6 Replies
Im in need of urgent assistance, this is my situation.
I started the QTO Workbook and adjusted the units in my current project. Now i saved out the XML file and im trying to import it into another part of the project that someone had created. My problem is when i try and import it, someone started the QTO workbook and used the wrong variable units. So when i try and import i get this error. PLEASE HELP!
Tags (2)
6 REPLIES 6
alan.quinn
in reply to: rgilbim
The message you see is expected and as designed "The selected catalog cannot be imported in your Quantification project. Please select another catalog that has the same variables and measurement units as your current project"
You will either have to use your Workbook or the other. I'm not aware of any way of compiling when the variables are different.
Thanks for posting.
rgilbim
in reply to: alan.quinn
Your misunderstanding what im saying.
IF i need to remove the workbook with Imerial units per say. and reimport one with metric becuase the project standards changed. How is this possible ???
rgilbim
Any thoughts ???
k.jayavijayan
Hi
If you export the catalog in "Imperial" then the destination file also should be in Imperial. If it is Metric, you'll get the "Variable error".
Better import the catalogue in the "quantification Setup Wizard". So you can change the units at the beginning itself or else you can't import external catalogue(where it's units are different than the present catalogue).(See screenshot)
Suppose if you have created the catalogue with different units and want to use with future projects, you may edit the catalogue file (*.XML) to replace all metric units to imperial or Viceversa
1. Open the catalogue in Notepad
2. Copy all the contents to Microsoft Word
3. use "Find and Replace" to replace text related to units
              For e.g
              Meter to Feet
              Squaremeter to Squarefeet
              Cubicmeter to Cubicfeet
              Metric to Imperial.
4. Always make a backup of original catalogue file before changing anything.
There is no reset option for product catalogue in Navisworks. I found the above onlyway to import catalogue with different units.
rgilbim
in reply to: k.jayavijayan
Thanks Kayj. Thats what my questions was reffering too. I had already created a custom workbook with all the custom omniclasses. So I didnt want to recreate the workbook having different units.
p-dandrea
Hi, I would have a solution regarding this message:
1) Open a new file
2) Upload any .nwc file
3) Upload the new .xml file (QTO custom catalog)
4) Add the old .nwf file
All information will be uploaded except that of the QTO because it is present.
Rail Community
