I've got a NAVIS file but when I try to navigate thru it, if I run into conduit, duct work, or any objects in the model, it stops me cold. Is there a command or setting that allows me to pass thru the objects like I normally do?
found it... Viewpoint tab > motion settings panel > realism drop-down>uncheck (or check) the collision check box or cntrl + D for short
