Navisworks General
New Member
diezfm
Message 1 of 3 (517 Views)
Navisworks timeliner + presenter lighting
517 Views, 2 Replies
06-07-2012 03:07 AM
Hello.
I don't know if I'm doing something wrong when exporting an animation combining presenter + timeliner. I get a lot of problems like different lighting during the animation. When, for example, a machine appears, the scene gets a higher illumination and when it dissapears it goes dark.
I'm exporting frames (.png) and getting different lighting in each frame, happening wich you can see in the video (a scene that change continuously from clear to dark).
I'm importing a FBX file from a model in 3ds max, with ambient and distant lights and materials from recommended tab.
http://www.youtube.com/watch?v=FCQt1Jpv4lA&feature=plcp
Thank you very much.
Francisco Díez
Active Member
seanzook4385
Message 2 of 3 (509 Views)
Re: Navisworks timeliner + presenter lighting
06-07-2012 04:07 PM in reply to: diezfm
My guess is you have Autoexposure selected in the Prenter "Rendering" tab. This will cause the lighting to change from frame to frame, particulary on 4D because new content is added to the scene and the exposure is then recalculated.
New Member
diezfm
Message 3 of 3 (504 Views)
06-08-2012 06:03 AM in reply to: seanzook4385
That's it!!
Thank you very much, I was fighting with this problem from time ago!
best regards
You are not logged in.
Have API Questions?
New Dedicated Forum for Navisworks API
Ask the Community
