Hi, anyone knows how I can upload a file to the web Navisworks to areas outside of where models can see the progress we are having on your 3D model. Whether in HTML, Java, visual, and so on.Thank you.
Solved by lee.mullin. Go to Solution.
I'm not quite sure if I understand what you are trying to do.
You can use the ActiveX plugin in the API folders on the product to create a Web viewable model. This has limited functionality but using the API you can add additional features that are available in the Freedom product. If you needed more features that are not available in Freedom then each user would needa license to be able to access these features.
Here's some more information about the Autodesk Developer Network who can help you with using the API.
If I have misunderstood the question, please let me know.
Good if you just want to make a site where construction managers can visualize the progress and how your building model almost immediately through the web do not know if this is also done directly with freedom and visual basic, thanks
This is an example of the ActiveX control in use: -
http://www.aec-area.co.uk/NW/NW-Demo.htm
If you just want people to visualize sections, or viewpoints then this is possible
Well thank you, your information has served me much hope and can do, otherwise you know you have a scope within NavisWorks API ?
It depends on exactly what you want to do, if you can provide a list of features you would want access to then I'll see if we can get information from ADN about what which features are accessible throughthe API.
Thanks, I want to do, is make some applications to enter into the desing of any model, in timeliner use the movements, the movementes that are repetitive(trucks) or something
HI, can you tell me how I add the ActiveX at code to view the models.
thanks
Hi For the demo I got to see how the ActiveX and the like, this very well indeed and I have almost finished my driver but when we want to see the models. Nwd I display them in my intranet as the direction from a local folder, but the projects have to be in the same visual studio project, or Imight say as you entered the DropDownList models and could read them. They put in a shared folder?, From the server? Or how I can do topull all my models without display problem on machines that are notinstalled Navisworks? thanks I hope you can help me
