Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Navisworks Simulate 2013 NWD Loading Problems
3 REPLIES 3
atgiacalone
896 Views, 3 Replies
We have just installed Navisworks Simulate 2013 on (3) machines.  (2) of our computers have Navisworks Simulate 2013 installed from the Autodesk Building Design Suite disk and the other is installed from the Autodesk Navisworks Simulate 2013 disk. You are probably wondering why I would bother telling you where the installs came from, and I will explain below.
We have noticed that the same NWD file on the (2) computers where Simulate 2013 was installed from the Autodesk Building Design Suite disk, loads a lot slower then the computer that Simulate 2013 was installed from Autodesk Navisworks Simulate 2013 disk.  The (2) computers that Simulate 2013 was installed from the Autodesk Building Design Suite disk experience huge slow downs when appending in or just opening NWDs.  The (1) computer that was installed from the Autodesk Navisworks Simulate 2013 disk does not experience this slow down.  It doesn't make any sense that the same exact file to perform differently on the (2) computers installed from the Autodesk Building Design Suite disk vs the (1) computer installed from the Autodesk Navisworks Simulate 2013 disk.
Does anyone have any ideas?
Thanks!
3 REPLIES 3
On both computers (Simulate disk or Building Desing), export the workspace to an XML
and export all the options (optons editor) to an XML.
Load the XML ont the other computer and see if the problem dissapears or moves to the other computer.
If so, it's somewhere in the Workspace or Options.
My guess is it's somewhere in the file or caching options.
I have tried exporting the options from the working 2013 Simulate installed from the Simulate Disk, and importing the XML file into the 2013 Simulate installed from the Building Design Suite Disk with no difference loading times.  I will try the reverse to see if I get a difference on the 2013 Simulate installed from the Building Design Suite Disk.
I have turned on the Logging and Enable Console option in the general tab (holding shift and clicking options) and attached the Navis Logs so you can see the difference in loading.
The log shows that to open the same NWD on both installations, 2013 Simulate installed from the Simulate Disk took 0.702 seconds, while 2013 Simulate installed from the Building Design Suite Disk took 4.89 seconds to load.
It's really not that much longer, but the real lag comes in when refreshing, appending, or even deleting files from an NWF.
Thanks for your help!
If it's not the Navisworks options, it could be other things
1) network connection and speed
Is the NWD on a network drive ?
try to copy it first to a local drive an see if that makes difference.
Has the slow computer "unavailable" network connections if you ask NET USE in a cmd  -prompt window ?
Have both computers the same network speed and duplex ?
2) software security
are the DEP settings the same ?
have the end-user the same (adminitraro / power user / urer) rights on the machines ?
3) software dependencies
Look on the installation DVD of Simulate to see what prerequisite software is needed, like .net or whatever
check if those have the same version
4) hardware and drivers
same here: same hardware and same grapic card drivers ?
Good luck in finding the difference
Rail Community
