New user here,
With the upgrade to 2013 Navisworks Manage, with Service Pack 2 installed, When I transform files from their amended elevation which was changed in AutoCad 2013 to 156'-0", back to a zero z elevation by doing the following:
Selection Tree:
Select file
right click
over ride item
override transform
change it from (0,0,0) to (0,0,-156ft 0in)
it moves the files.
As soon as I do that, and I do the same command, it shows the transformed location to (0,0,0) again.
What this means is that I am unable to reset transform of any of my files. I have to manually transform them to the 156' z coordinate.
The only reason I want to be able to reset is that there are times when I want to add a floor above or below to the model to coordinate vertical runs of conduit with other trades and steel.
Please help as this is really bothering me, and a few other people at different companies do not have this issue, yet both my co worker and I DO have this issue.
Kevin
I am also having this same issue but using Naviswork Simulate 2013.
Please help.
