Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Navisworks Manage 2012 -- Update Drawings
1 REPLY 1
AReitter
837 Views, 1 Reply
If you are using a NWF file with Navisworks Manage 2012 can you refresh just one of the files it is linked to?  I have a project with 15+ files pulled into the Navisworks model and refreshing all of them takes several minutes.  It would be helpful if I could refresh just the file that I am working in.
Edited by
Discussion_Admin
1 REPLY 1
lee.mullin
in reply to: AReitter
Hi AReitter,
Welcome to the forum.
I've moved this into a seperate post as it's a slightly different issue.
If you are using NWC cache files then it is possible to refresh individual files if the others haven't changed. You just need to be aware of situations where we 'think' the file may have changed.
More details can be found on our blog here
http://beyonddesign.typepad.com/posts/2011/06/tango-and-cache.html
Lee Mullin
Construction Technical Specialist
Autodesk Ltd.
Rail Community
