Navisworks General
New Member
obakerwr
Message 1 of 3 (440 Views)
Navisworks Clash Detective Help
440 Views, 2 Replies
05-07-2012 07:31 AM
I have Navisworks Manage 2011 and have been using it the last few weeks to identify clashes and create clash reports. I am still getting used to all the functions of the clash detective tool. I have found that the clash report format does not have a tabular report format that would be helpful in sorting and filtering the data. I noticed that there is a hotfix for the tabular HTML report in the 2012 version, but I have not been able to find anything for the 2011 version. Is there anything like this hotfix that exists for the 2011 version?
Also, I have found that when I run the clash detective tool, sometimes I get hundreds of false positives (redundant clashes). Our designers use PDS; so is this just a product of how the basic geometries are created? Is there a way to reduce the number of redundancies without going through each and every clash?
Thanks!
Bill
Valued Mentor
dennis
Message 2 of 3 (438 Views)
Re: Navisworks Clash Detective Help
05-07-2012 07:37 AM in reply to: obakerwr
The tabular layout for reporting is a 2012 thing, wasn't available in 2011.
Possible help on the extra clashes:  On the rules tab:  Ignore clashes in groups/blocks/cells and ignore clashes in composite objects.
dmurov
Message 3 of 3 (380 Views)
06-11-2012 09:34 AM in reply to: obakerwr
Redundant Clashes:  We are also looking for a solution to this problem.  Some files we have received are created with poly face mesh objects and result in 20+ clashes that should only result in "one" clash.
I've found one suggestion that allows grouping clashes involving a specific item...Still time consuming and results in additional folders when creating viewpoints.
Clash Detective - Results tab - The Items Expandable Panel
  • "Group Clashes Involving Item" - creates a new clash group containing all clashes involved with the item or items that you have right-clicked on.
  • If both items in conflict are polyface mesh or broken down into several parts, this solution does not work very well.
You are not logged in.
Have API Questions?
New Dedicated Forum for Navisworks API
Ask the Community
