Im curious. I tried installing SP1, i have been hacking a lot of crashes and bugs on older files with viewpoints.
1 - My install kind of went dead towards the end. not sure if it installed or not. - is the built version 11.4.0.101763 ?
2. I see new Rules in the Clash Detection editor under the new features. Are these built in ? I dont seem to have any of the ones discussed in the new features.
Thank you for your post. In this case there was an additional hotfix released after this update for the NW 2014 product to address some performance issues and overall operability that was found after the update release. Has this been applied as of yet? Please refer to the link below to first add this into your installation and then test. Please keep us posted and let us know how this worked out. Thank you and we look forward to your reply update.
NW 2014 Hotfix: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22506086&linkID=10382102
Thanks, DL the hotfix and updated. I cannot per say it has fix it until i work on it further. However,
1. Can you confirm i have the latest build with that version for SP1.
2. after installation i still do not see the Rules Editor features for 2014 ?
Rg
Any Updates with my Rule Editor Issue.
Attached find 2 Screenshots. 1. My current Rules Editor rules, and the 2014 Features I assumed I was going to have. (Composite Features)
Are these predefined or do I need to set them up ? Please Help.
RG
Thank you for your post. The list of rules and options you have added is identical to my lists in all 2014 configurations here. Was there something specific, that you are looking for? Do you have a screen shot of this alternative list that is desired for reference?
Please keep us posted. Thank you.
