The Navisworks 2013 Service Pack 1 is now available from: -
http://usa.autodesk.com/getdoc/id=DL19840757
See the blog below for more details about fixes included in this release
Solved by lee.mullin. Go to Solution.
Service Pack 1 fixes are included here: -
The readme isn't clear on one point. It seems to say that the SP can be appended to a deployment, which is different from previous Navisworks SP's. Is this correct?
that is correct
i think in previous years it was an .exe that contained multiple .msps
DarrenP
My NWManage updated fine. The update of the 2013 Freedom Viewer, in my case, the 64bit version doesn't 'see' that it is already installed and so won't upgrade it. Anyone else seeing this happen?
I have installed the latest service pack on my computer as well as other co-workers' machines and it appears as though some of the fixes are still an issue with the latest service pack. for example, our tolerances reset everytime we run a clash detection. Anyone else having this problem
I have moved this to the Installation and Licensing Forums http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
