Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Navisworks 2013 - Arcs showing as straight polylines
1 REPLY 1
tyr_tomkem
690 Views, 1 Reply
Hi!
I am putting together a composition model from infrastructure models such as roadway in 3D-solids, bridges and construction.
When I append a DWG-file with containing polyline that contains lines and arcs, Navisworks shows the arcs as straight elements.
See the captured photo below which is taken directly from Navisworks.
  1. How do i manage this with Navisworks 2013?
  2. The DWG-file has a witdh to all the polylines and in Navisworks these does not show. How can I manage this?
Arcs in Navisworks 2013
1 REPLY 1
kathryn.langan
in reply to: tyr_tomkem
This is known behavior that arcs will be converted to a series of straight lines, but you can control the facets in Navisworks which may help:
Katie Langan
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
Rail Community
