Hi!
I am putting together a composition model from infrastructure models such as roadway in 3D-solids, bridges and construction.
When I append a DWG-file with containing polyline that contains lines and arcs, Navisworks shows the arcs as straight elements.
See the captured photo below which is taken directly from Navisworks.
Solved by kathryn.langan. Go to Solution.
This is known behavior that arcs will be converted to a series of straight lines, but you can control the facets in Navisworks which may help:
