I downloaded and installed the Navis Works Exporters and the Navisworks C3D object enabler http://usa.autodesk.com/adsk/servlet/ps/dl/index?linkID=10382102&id=2334440&siteID=123112#section1 but still the C3D objects are not displayed in NAvisworks; I tried rebooting before posting this.
Solved by lee.mullin. Go to Solution.
Can you go into the Navisworks Options (Applcation Button > Options) > File Formats > DWG/DXF and ensure the Loader year is set to 2012 and the Render Type is set to Shaded?
More information about object enablers and not being able to see objects can be found on our blog
http://beyonddesign.typepad.com/posts/2011/06/now-i-know-i-left-my-model-around-here-somewhere.html
http://beyonddesign.typepad.com/posts/2011/06/so-my-model-is-there-you-say-i-just-cant-see-it.html
If this doesn't work can you please send the NWC created and a screenshot of the Scene Statistics window (Under Project on the Home Tab)
the render type was set to automated and I changed it to shaded , now everything looks good!
Triangles, Lines and Points: 995623
Bounding Box: (7.86862e+007,2.32007e+007,-162.577),(7.87658e+007,2.32536e+007,621.92)
MER99_RGW_CIFE_NWCOUT_20110810_test.dwg
Processed 507 LINE
Processed 5 POINT
Processed 285 CIRCLE
Processed 511 TEXT
Processed 773 ARC
Processed 119 SOLID3D
Processed 2557 LWPLINE
Processed 839 GENPROXY
Processed 395 LAYER
Processed 5 VIEW
Processed 69358 GR_POLYLINE
Processed 1206 GR_SHELL
Processed 6 GR_TEXT2
That's great to hear, thanks for using the forums
