Navisworks General
Valued Mentor
granite07
Message 1 of 6 (1,344 Views)
Navisworks 2012 and Civil 3D 2012 object enablers and NWCOUT
1344 Views, 5 Replies
08-10-2011 02:56 PM
I downloaded and installed the Navis Works Exporters and the Navisworks C3D object enabler http://usa.autodesk.com/adsk/servlet/ps/dl/index?linkID=10382102&id=2334440&siteID=123112#section1 but still the C3D objects are not displayed in NAvisworks; I tried rebooting before posting this.
Forest Peterson, granite@stanford.edu; build-sheet
Product Support
Message 2 of 6 (1,337 Views)
Re: Navisworks 2012 and Civil 3D 2012 object enablers and NWCOUT
08-11-2011 02:36 AM in reply to: granite07
Can you go into the Navisworks Options (Applcation Button > Options) > File Formats > DWG/DXF and ensure the Loader year is set to 2012 and the Render Type is set to Shaded?
More information about object enablers and not being able to see objects can be found on our blog
http://beyonddesign.typepad.com/posts/2011/06/now-i-know-i-left-my-model-around-here-somewhere.html
http://beyonddesign.typepad.com/posts/2011/06/so-my-model-is-there-you-say-i-just-cant-see-it.html
If this doesn't work can you please send the NWC created and a screenshot of the Scene Statistics window (Under Project on the Home Tab)
Lee Mullin
Product Support Specialist
Global Services
Autodesk Ltd.
Valued Mentor
granite07
Message 3 of 6 (1,327 Views)
08-11-2011 08:33 AM in reply to: lee.mullin
the render type was set to automated and I changed it to  shaded , now everything looks good!
Triangles, Lines and Points: 995623
Bounding Box: (7.86862e+007,2.32007e+007,-162.577),(7.87658e+007,2.32536e+007,621.92)
MER99_RGW_CIFE_NWCOUT_20110810_test.dwg
    Processed 507 LINE
    Processed 5 POINT
    Processed 285 CIRCLE
    Processed 511 TEXT
    Processed 773 ARC
    Processed 119 SOLID3D
    Processed 2557 LWPLINE
    Processed 839 GENPROXY
    Processed 395 LAYER
    Processed 5 VIEW
    Processed 69358 GR_POLYLINE
    Processed 1206 GR_SHELL
    Processed 6 GR_TEXT2
Product Support
Message 4 of 6 (1,323 Views)
08-11-2011 08:36 AM in reply to: granite07
That's great to hear, thanks for using the forums
Lee Mullin
Global Services
Autodesk Ltd.
Member
Message 5 of 6 (1,273 Views)
08-17-2011 04:19 AM in reply to: granite07
All good, but where do I find them?
Member
Message 6 of 6 (1,272 Views)
08-17-2011 04:27 AM in reply to: ewing
sorry, ignore that... When in doubt, Google it out!
You are not logged in.
Have API Questions?
New Dedicated Forum for Navisworks API
Ask the Community
