When is have marked up clashes in Navisworks 2013 with Service Pack 2 installed. When I produce a report to Viewpoints the markups do not go over to the Viewpoints.
I think they did before Service Pack 2 was installed.
Is there a way to get the markups to carry over to the Viewpoints?
Solved by richardparker. Go to Solution.
Hi Hank, you can find a hotfix for that problem here http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20626807&linkID=10382102
Best regards
Richard
The hotfix for markups in clash detective will not recognize that SP 1 and 2 are installed and so the hotfix fails.
Does anyone have a fix for this?
