Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
NavisWorks Data tools
2 REPLIES 2
jamierichard
2036 Views, 2 Replies
I am using NavisWorks Manage 2009 and am trying to establish a data link with Bentley AutoPlant. I am using standalone bentley project so the database is local MS Access file. I am also using the standard datalink for local project provided by Autodesk/NavisWorks. When I do the datatools in NavisWorks 5.5 I have not problem seeing the AutoPlant data, when I try the same with NavisWorks 2009 I don't get the AutoPlant Data, not tab under properties or anything. Any help or suggestions would be appreciated.
2 REPLIES 2
It simply didn’t work on NW2009 with AP XM.
You need to install NW2010 for that....no other solution.
The reason for that is that NW2009 just isn't bringing in the Comp_ID, needed for establishing the link.
A work around: create an NWD with NW5.5, and open it in NW2009.
This because NW5.5 brings in the Comp_ID into the NWD.
So you can create a datalink from within NW2009 between the created NWD V5.5 and the DB.
Marc
mmhill
in reply to: jamierichard
I am trying to configure NavisWorks 2010 SP1 to connect to an Autoplant Central Multi-Project database that has been integrated with Bentley ProjectWise. I am using the "Oracle 10" datatool. What modifications to the SQL String do I make to point to a specific Autoplant Project ID? I have attached a copy of the default string.
Rail Community
