Hi
I have come across an issue which is happening on multiple PC's in our office where when a user tries to make the point sizes in navis bigger you make the number higher and it does nothing. we are using Navis 2014 and all service packs are installed.
It happens on diffrent drawings, I have already been advised to update video drivers on the PC but this hasnt helped.
Any help would be great thanks
Hi Thanks for the reply when I go to options then interface then display, I only have two avialble options Autodesk or drivers there is no such option
Thank you so much for your help means a lot ! do you know much else about navis I have an issue where the same drawing is being opened and on every pc it is opened on it crashes navis and says out of memory
