HI,
On this same topic, is there a way to change all the viewpoints at the same time, to the 45 degree setting? We are currently using an outside program to create viewpoints in navis, and the Field of view is being changed to around 125 degrees for all viewpoints which is beyond fishbowl, and it would be far too time consuming to changes these one at a time. Or do you know of a way to permanently lock the field of view to 45 degrees? I see no real reason to ever differ from this setting for how we use Navisworks in construction. Any input would be greatly appreciated! I know this is an old thread, we're using 2017 Navis, but searching for answers where ever I can. Thanks!
yes,
Make a backup of your NWF / NWD.
export the Viewpoints to XML (Viewpoints Dialog -> Right mouse menu)
edit the XML
delete all ViewPoints in Navisworks
Import the Viewpoints XML
Beware: all color and hidden overrides which were might be stored in your viewpoints are lost using this procedure.
