Hi,How do I change the size of the pictures made by the "Export viewpoints Report" feature? They are currently 512 x 512 which is not enough to make the feature useable!
Solved by DavidThirlwell. Go to Solution.
In Navis, click the Big N button, then Hold Shift on your keyboard and click Options. Under Interface, Viewpoint Defaults, Viewpoints Report, Image Height/Width to the images size you want.
You want to keep this image on hand. Very handy with image exports. I export depending on the projector / screen required.
