Hey all, I am batch exporting a folder full of .nwf's which are built up of a .nwc file, complete with clash results. I need the .nwf to host the clash results as the .nwc updates and the clash detective re-runs against the new .nwc. My problem is I lose all of my clash tests and results when I use the Batch Utility to save these out to .nwd. If I Save-As the .nwf into .nwd format then all the tests and results go with it.
Am I missing something here?
Cheers,
Chris
Solved by AndyG_ADSK. Go to Solution.
Hi again Patrick. The issue is not with Freedom (my typical process would save all clashes as viewpoints for Freedom users) but with exporting a 'clashed up' .nwf to .nwd with the batch utility and losing all clash tests and results when I open the exported .nwd in Manage. Does anyone follow this workflow and do they get a similar result?
Cheers.
Chris,
This is an issue with Batch Utility in 2014. It doesn't load plugins, of which Clash Detective is one, and any plugin data gets lost. It is fixed in 2015.
Cheers
Andy
Thanks Andy. I have tested this and can confirm that it works. A bit of an oversight in the 2014 products I guess.
Thanks again,
Chris.
