Navisworks General
Member
mickiebims
Message 1 of 2 (164 Views)
Moving / Transform in the negative direction using Feet & Inches
164 Views, 1 Replies
04-26-2012 11:35 AM
When moving a piece of my model geometry in Simulate 2012 I might type -22ft 6in.  Should be fine it does move the object but when I check it again it will say it moved -21ft 6in.  Moves fine in the positive direction but when moving negative It's always 1' less than what I'm trying to get.  Any ideas..?
Mick
Contributor em
em
Message 2 of 2 (133 Views)
Re: Moving / Transform in the negative direction using Feet & Inches
05-10-2012 12:13 PM in reply to: mickiebims
Same strange behavior in Manage.
If i want to move an object on negative z and enter '-3ft 6in' for example, after i leave that text box it shows '-2ft 6in'.
I have to put a minus sign before the inches also to have it move right, like '-3ft -6in'.
Also there are some other strange behaviors of these textboxes where you enter values to manipulate objects, depending the way you enter the values. Probably they were design to work with metric system and are not workig too great with the imperial units.
You are not logged in.
Announcements
Have API Questions?
New Dedicated Forum for Navisworks API
Need installation help?
Ask the Community
