Has anyone else experienced that modellines don't export to nwc anymore in revit 2014. Navisworks also does not seem to convert the modellines from an rvt file.
Both ways were working in 2013
Hi Daniel,
so far I can only confirm this behaviour, and apologies for the delayed response on here.
Can you tell me what you're using the model lines for in Navisworks?
Best regards,
Thomas Schwaiger
Autodesk | BIM 360
Hello Thomas,
I link dwg files in revit. Set the project base point correctly. Next I draw a couple of revit model lines on top of the dwg drawing.
next i export those model lines to navisworks
In navisworks I append the nwc from revit and the dwg. If everything has been setup correctly they match. That way I ahve checked that everything I model in Revit will end up on the right coordinates
