Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Model doesn´t display
3 REPLIES 3
clacampos
348 Views, 3 Replies
I create an NWF file in Navisworks 2013 with 2 RVT files in a note book. When I open the same file in a desktop computer the model is not displayed. Does anyone have an idea why?
Claudia Campos
Você achou uma postagem útil? Então fique à vontade para curtir essas postagens!
Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão 'Aceitar Solução ' .
Claudia Campos
Comunidade de Usuários Autodesk Português - Coordenadora
3 REPLIES 3
CesarEscalante
in reply to: clacampos
Check the paths.  Assuming the files are on a server, is the server location mapped the same way in both computers?
On the Laptop, append the same models again, but only use UNC path to browse to them, like \\server\Share\Folders\filename.ext
Then Detach the first files you appended, so that you don;t have them twice in your NWF
Then Saveas the NWF as attempt2.nwf
Then try to open this attempt2.nwf on the other computer.
Hello!
Thanks for the prompt answer but I found the problem.
The Revit files didn´t use Shared Coordinates in this project as usual for me. It was using Project base Point, so in Navisworks I had to set RVT files to import using Project Internal!
Claudia
Claudia Campos
Rail Community
