I have a one rule I can figure out how to work (Materials by property). As long as the material body color in autocad is a standard autocad index color I can attach material wiith the rule. But I have several materials that have a body color of a true color (i.e. 168.168.168). Does anyone know how I can use a rule to attach a material to a color that has a true color number for its material.
Any help with getting the first three rules to work would be appreciated..
Thank you for your post. In this case there sounds like an opportunity to create view filters for varying objects within the Revit software. For reference I have included a helpful link below that may shed some light on this process and how to maybe achieve the desired output. I hope this helps.
Post: http://allaboutcad.com/07/create-view-filters-in-revit-by-material/
