Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Manually remove Navisworks Simulate?
2 REPLIES 2
nathan.smith
559 Views, 2 Replies
Hello - I have two Windows 7 64-bit computers that were running Navisworks Simulate 2013 with a network license. Simulate was later uninstalled from each workstation, with the intention of installing Navisworks Freedom instead. While attempting to install Freedom , the program fails with an error that the application already exists on the system.  Are there any folders and/or registry entries that need to be manually removed to complete the Freedom installation?  Any help/suggestions would be much appreciated!
Thank you,
Nate Smith
Redi Engineering Services
2 REPLIES 2
dgorsman
in reply to: nathan.smith
Usually not.  When deployed or installed, Simulate includes the option to install Freedom as well.  You might want to check to see if Freedom is, in fact, already installed first.  If not, then do a clean uninstall.  Revo is seems to be the most recommended, although you should probably check the Knowledgebase for clean unstall procedures first.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
nathan.smith
in reply to: dgorsman
Thanks for the quick reply - we'll try your suggestions.
Nate Smith
Rail Community
