I recently installed Navisworks Manage 2015 and I seem to have lost the Element & Revit Type in the properties window and I cannot find it. It seems to still be reading the Revit parameters as the quantification catalog formulas I had written still generate values based on the variables I had defined from the tab in Manage 2014.
Can anyone help me get the tab or let me know where it got moved to?
Thank you for your post. In this case one quick thing to check is to ensure the palette is activated. To do this you can navigate to the View tab on the ribbon, and then under the last panel, workspace, and then select Windows drop down. This will have a flyout with all the available palettes to activate in the view. Please check here first and keep us posted. Thank you.
The properties window is open and displaying, it is specific "TABS" within the window that I cannot see in 2015 that I used extensivly in 2014 such as Element Tab and Revit Type. Like I said, I can map to the items in those tabs I just cannot see the tabs displyed in the window any longer. Is there an option for turning on/off tabs within the properties window?
Select an element and right click, select "Set Selection Resolution to First Object"
A bunch of new (and old) property tabs should show up
This can also be change in the Home ribon under "select & Search" or in the options under "Interface --> Selection --> Resolution --> First Object"
