Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
MEP Pipe sizes in Navisworks
2 REPLIES 2
sethfranklin4567
1685 Views, 2 Replies
Our engineers use Navisworks to review models and they are unable to see what size a pipe is modeled to.
Is it possible for Navisworks to list a Pipe size that was modeled using MEP? We are using MEP 2008 and Navisworks Review 2009.
Thanks in advance
2 REPLIES 2
in reply to: sethfranklin4567
We only have NavisWorks Manage in our office so this answer is coming from that perspective. You should be able to select the object in question using the Selection tool and then open your Properties dialog box. The size of the pipe should be listed in the Properties dialog box once the item is selected. I hope this helps.
If this property is something you want quick access to all the time, you can customize Smart Tags to include it using the Global Options interface. Then with Smart Tags turned on, you'll get a tooltip with the information whenever you move the mouse over an object.
Tim Wiegand
Software Architect
Rail Community
