I installed nav in windows 7 32 bit and working properly.
but when installed on Windows 7 64 bit it shows the message "A valid license could not be obtained by the network license manager Error [0.0.0]". Can someone help me, I use it on the network.
tks
Hello LeoAndrade,
You are looking for the “Installation & Licensing” discussion group. It is located here: http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
A 0,0,0 error could mean a variety of things. If the request hits the license manager I would expect an actual error value to display, not just zeros. You will want to make sure your license manager is up and running, and that you are pointing to the correct location.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240617&id=9480492&siteID=123112
Thank you for participating in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
This has been moved to the Installation and Licensing Forum
