Navisworks General
New Member
alanbarn
Message 1 of 2 (166 Views)
Is it possible to alter the horizon Height, or add a plane (Sea level)?
166 Views, 1 Replies
07-11-2012 07:15 PM
I am working with a model of an offshore platform.
I'd like to show the Sea level (part way up the legs).
Can I alter the horizon elevation?
Can I add a plane to represent the Sea level?  (which I can preferable go below and above).
Valued Mentor
Message 2 of 2 (163 Views)
Re: Is it possible to alter the horizon Height, or add a plane (Sea level)?
07-11-2012 10:50 PM in reply to: alanbarn
The way I would do this is create a new AutoCAD drawing,
draw a circle at 0,0,0 with a diameter of a mile or a km, and then extrude it 1 inch or 1 cm down.
Now you got a new DWG that has the plane
Append this DWG to your model.
"File units and transform" this model or all other models until it is at the right spot.
You are not logged in.
Announcements
Have API Questions?
New Dedicated Forum for Navisworks API
Need installation help?
Ask the Community
