Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Insulation problem- Plant3d piping
5 REPLIES 5
1414 Views, 5 Replies
I am having an issue with my piping insulation showing in simulate 2011. Insulation shows up fine in Plant3d 2011 when insulation is toggled on. If I toggle insulation on in Plant3d and save, when I open the dwg in Simulate the insulation is not shown everything elase in the model is fine just no insulation. I have tried many times and deleted all nwc files just in case. It use to show insuation fine. Anyone have any ideas?
5 REPLIES 5
lee.mullin
Do you have a sample model? Does this also happen in the 2012 products?
Lee Mullin
Construction Technical Specialist
Autodesk Ltd.
in reply to: lee.mullin
I am having the problem with both 2011 and 2012 products.
Also with some more testing I have found that if I use NWCOUT command in Plant3D the .nwc file produced shows insulation correctly when opened in navisworks. I have attached a dwg I am having the issue with. I have tried other dwgs also.
dwg link: https://docs.google.com/leaf?id=0B6ITVsGSYcI5MjU1ZDczM2YtYjZhNS00YmFiLWE0YzktN2VkYjkzMjY0Nzdj&hl=en_...
lee.mullin
It looks like you'll need to load this in 2012 with the Plant 3D 2012 Object Enabler
Make sure you have the Loader Year in DWG options set to 2012 and the Render Type to Shaded.
Please let us know if you still have problems.
Lee Mullin
Autodesk Ltd.
I have the 2012 object enablers installed. I have reinstalled the object enablers and Navisworks but still having the same issue. I am going to post 4 pictures showing what I get when using 2011 file type with 2012 object enablers ( at least I get some sign of insulation.) And the second set of pictures will show 2012 file type loading the same exact file.
Last picture attached...
Rail Community
