Navisworks General
Member
Message 1 of 4 (864 Views)
Importing PDS (.dri) files in Navisworks Simulate 2013
864 Views, 3 Replies
11-07-2012 06:55 PM
I am trying to open dri files in Navisworks Simulate 2013. But the program crashes after 12%.
I'm using  a Dell T7600 with WIndows 7 64 bit, Dual Xeon processors, 128 GB RAM, Quadro 6000.
Thanks in advance.
SHMolla
Valued Mentor
Message 2 of 4 (815 Views)
Re: Importing PDS (.dri) files in Navisworks Simulate 2013
11-13-2012 04:30 AM in reply to: shmolla
Thy one or all of these:
Check if "load references" is OFF at the options of the DGN, check if load PDS data is ON.
PDS files tend to have lots of references referencing each other.
Do not load the dri file, but append the DGN files with 10 at the time. Save the nWF whenever it succeeded.
the corresponding drv file with the same filename will be loaded also.
Use Navisworks 2012. 2013 has definity a problem with PDS component data, i'm not sure it is solved with the latest 2013 serivce pack.
New Member
Sameer_Band01
Message 3 of 4 (674 Views)
02-11-2013 02:55 AM in reply to: shmolla
Dear sir i want more information on pds (.pri) file. can any one provideing me one sample file .pri for R and D
Thanks & Regrds
sameer
New Member
AbdulBasit1473
Message 4 of 4 (477 Views)
04-08-2013 06:05 AM in reply to: shmolla
We have a DRI file set and it does get loaded into Navis Simulate when we select the options in the file reader. When we try to "Save As" the file into a Navis there is a huge memory consumption during the save as operation and software gives an out of memory message during the save operation.
How can we solve this problem?
You are not logged in.
Have API Questions?
New Dedicated Forum for Navisworks API
Need installation help?
Ask the Community
