Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
INCORPORATING ALL PROPERTIES OF A CAD BLOCK AS A TOOL TIP IN A NAVIS PROPERY
10 REPLIES 10
Message 1 of 11
BIMAbhi
1283 Views, 10 Replies
When we are importing a CAD block in  a navis file we cannot see the entire tooltip with all properties parameter which are provided in a block such as Manufacturer Name,Model Name etc.The attached image shows only Name and Item Type.We need all the block's property in the Tooltip content in Navis Works interface.Is there a way out.
Thanks & Regards
BIMAbhi
10 REPLIES 10
Message 2 of 11
john.lipp
in reply to: BIMAbhi
Hi RNDPIS
Please check the following :
Open the properties tab in the selection tree and check the Properties tab.  Is the property available in Navisworks?  Another method would be to take a known value of a property and enter it in the quick find box in the Selection & Search Tab of the Home Tab.  If the property isn’t available, could you send a sample DWG?
If the property is listed but not showing up in the quick properties, ensure that you’ve added it under Application Button > Options > Interface > Quick Properties > Definitions.
If the property is there, and you’ve added a quick properties definition, then the issue may be the selection resolution.  There is a similar posting in this regard in the link below:
http://forums.autodesk.com/t5/Autodesk-Navisworks/Select-objects-to-display-Quick-Properties/m-p/309...
Best regards,
John Lipp
Support Specialist
Product Support
Autodesk, Inc.
Message 3 of 11
BIMAbhi
Thanks for your support.
We have created the model with simple extrusion and added some custom property (Model, Manufacturer etc) and then it was converted to a block. In that case we want to show the customize properties in the navis interface. We have attached a png and the sample dwg block for your reference. We are waiting for your response.
Thanks & Regards
BIMAbhi
Message 4 of 11
dgorsman
Properties, or attributes?
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 5 of 11
BIMAbhi
in reply to: dgorsman
Properties !
We have created the model and provide the parameter in to the model. Can we show these custom parameter property in Navisworks? Please see the attachments for the procedure on how to add the parameter in CAD dynamic block.
Thanks & Regards
BIMAbhi
Message 6 of 11
john.lipp
Dear RNDPIS
I reproduced the same behavior. Unfortunately, properties created in this way don’t appear to be supported.
However, you should be able to create block attributes instead in the block and these will be brought through the Attribute category in Navisworks when you select the VAV boxes.
Could you give this a try?
I recommend posting this as a wishlist item through our feedback page:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Our development monitors the information that comes through this page, and coming from an end user, this offers a compelling business case.
Best regards,
John Lipp
Support Specialist
Product Support
Autodesk, Inc.
Message 7 of 11
BIMAbhi
We are unable to find the Attribute category in Navisworks though we have added the attributes on the vav block. Please suggest.
Thanks & Regards
BIMAbhi
Message 8 of 11
john.lipp
Could you send the DWG of the block you added the attribute to?
I’ve attached TEST.DWG and a video showing how it was created.
1. I opened your DWG
2. Right-clicked your block to edit it
3. Created an attribute with the tag TEST_TAG set to be invisible and placed the attribute
4. I closed the block editor and saved the block
5. I deleted the existing block and ran insert to insert the new one
6. I was prompted for the value and set it to TEST_VAL
7. I opened the Test.dwg file and selected the geometry with the selection resolution set to first object and the Attributes tab in properties shows the attribute.
Best regards,
John Lipp
Support Specialist
Product Support
Autodesk, Inc.
Message 9 of 11
awitt
Did you run BATTMAN after you added the attributes?
Message 10 of 11
john.lipp
I edited the block, used the ATT command to add the attribute, saved the block and exited the block editor, deleted the existing and placed a new block instance which prompted me for the value of the attirbute. I didn't use BATTMAN
John Lipp
Support Specialist
Product Support
Autodesk, Inc.
Message 11 of 11
awitt
in reply to: john.lipp
When you use BATTMAN and sync, it will update and add attributes to the existing blocks. The one thing to be careful is though, that you don't put a default value when defining the attribute, or it will fill all the existing blocks with it. All new blocks inserted will have the attributes.
Rail Community
