Navisworks General
*Expert Elite*
tcorey
Message 1 of 2 (299 Views)
How to specify an object is to work as a ground surface
299 Views, 1 Replies
12-16-2010 08:05 AM
When I try to walk on a Civil 3D corridor, I fall through unless I have also created a surface model of the corridor. Is there a way to specify that the corridor itself is an object that can be walked on?
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Product Support
Message 2 of 2 (296 Views)
Re: How to specify an object is to work as a ground surface
12-16-2010 10:39 AM in reply to: tcorey
Hello tcorey,
Navisworks needs to have a surface mass of some sort for collision to interact with. If you have gravity turned on, you will fall until you interact with an object. So, if you have a corridor with no mass to walk on, you would fall as there is nothing to interact with. If you turn off gravity, you will not fall.
I am not sure what your end goal is in this particular situation, if you are just walking around, turning off gravity after you reach the desired height is probably the way to go. If you were looking to try and make a walkthough of some type, I would make a viewpoint animation and let Navisworks take care of the camera movement.
Thank you for participating in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
You are not logged in.
Announcements
Have API Questions?
New Dedicated Forum for Navisworks API
Need installation help?
Ask the Community
