Hi everyone.
I'm New to Naviswork.. I'd like to see the schedule during my timeliner animation.
My problem is that when I save my animation I just see the "main" window and the schedule disappears.
Actually I'd just like to save what I see on my screen (attachment)..
Thank!
Solved by dgorsman. Go to Solution.
To the best of my knowledge, and I've been using NW for a long time, you can do what you are asking. What I do do though, is use my Camtasia program and record the screen, which will show the entire process. Not the best, but it does the job.
M
I think that should have been "... CAN'T do what you are asking." The schedule display is overlaid on what is sent to the display, which is separate from what is rendered to a file. If you want a text overlay in a stand-alone movie you need to either post-process or screen capture.
MY BAD......not enough coffee when I did that....or maybe too much........but that is Coorect...YOU CAN'T other than what I and dgorsman posted.
MY BAD!
M
