How to set background color & settings in a batch (command line) mode?
Provided the settings are available as global options, you should be able to specify specific options as XML and then load them on the command line using the argument -options. Defining the options as you prefer in the Navisworks Global Options and then exporting them as XML should give you a suitable starting point.
Hope that helps,
Jeff
