Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
How to display a draped image on a Civil 3D surface in Navisworks?
6 REPLIES 6
davebyrnes
4816 Views, 6 Replies
I'm using Civil 3D 2013 (very limited experience with C3D) and Navisworks Manage 2014. I have to create a Navisworks presentation of a development area that shows an ortho photo of the ground. I've managed to drape the image in Civil 3D which looks just the way I want it, but when I open the file in Navisworks I don't see the draped orthophoto, only the raster image sitting below the ground surface (see attached images). The draped image is listed as a material in C3D but when I open the Autodesk Rendering window in Navisworks it says there are no materials in this document.
How can I get the draped image to appear on the C3D surface in Navisworks?
6 REPLIES 6
dgorsman
in reply to: davebyrnes
I'm not certain you can.  There's a related post over at AUGI (heading out to a meeting right now - sorry I don't have a link handy).
Infraworks might be the better option in this case.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Lance.Coffey
The following blog posting has information on this topic:
Draping Aerial Photos on a Civil 3D Surface in Navisworks
Lance Coffey
Technical Support Specialist
lazicr
in reply to: Lance.Coffey
Lance, have you tried the solution you are suggesting?
Tags (2)
Lance.Coffey
in reply to: lazicr
I don't have a Civil 3D surface or matching image to attempt the process.
Have you had any success in using the steps from the blog posting?
Lance Coffey
JH-81
This is a 5 year old article and this is still the best work-around? I have tried but unfortunatley my 'image' comes in as a blank grey square so ther is no 'material' associated with it. Anyone have any advice??
in reply to: JH-81
I tried this workflow and was successful to a point. If someone can help on why the image is inverted and rotated 180 degrees clockwise. See images below. I am using C3D 2017 and Navisworks 2017.
Rail Community
